hugh_b Posted June 19, 2007 Report Share Posted June 19, 2007 Hey guys, just wanted to know what length cranks you are all running on your stocks, i'm running 175mm tensiles with an 18:15 gearing. I seem to clip them alot when doing hooks though and niggely things. It's probably just me not having the crank high enough to clear it but i would like to know if i could get away with running shorter cranks with that gearing. cheers-hugh Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted June 19, 2007 Report Share Posted June 19, 2007 175 burns with 16:14 gearing, i find the same, you get more power with shorter cranks too Quote Link to comment Share on other sites More sharing options...
hugh_b Posted June 19, 2007 Author Report Share Posted June 19, 2007 175 burns with 16:14 gearing, i find the same, you get more power with shorter cranks tooyeah i have been looking at changing gearing to 16:14, and maybe having 170mm cranks. This will give me a little more clearance all round and save a bit of weight. Quote Link to comment Share on other sites More sharing options...
Endohopper Posted June 19, 2007 Report Share Posted June 19, 2007 (edited) Conventional 175s ( absurdly heavy Race Face ) running 22 - 17 . I'm also rather curious how much weight can be saved by running shorter cranks , I'll check Tarty's site to see . Edited June 19, 2007 by Endohopper Quote Link to comment Share on other sites More sharing options...
Waddy Posted June 19, 2007 Report Share Posted June 19, 2007 i run 175 try all cranks with 18:16 gear ratio, i dont really seem to catch my cranks on hooks, but i think the higher bb also helps this Quote Link to comment Share on other sites More sharing options...
basher Posted June 19, 2007 Report Share Posted June 19, 2007 175........18:15........ How do you work that out that if you have shorter cranks you get more power. Longer cranks = more leverage = more force. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted June 19, 2007 Report Share Posted June 19, 2007 i run 175 try all cranks with 18:16 gear ratio, i dont really seem to catch my cranks on hooks, but i think the higher bb also helps this good point, my bb is +10 so thats probably it lol Quote Link to comment Share on other sites More sharing options...
Greetings Posted June 19, 2007 Report Share Posted June 19, 2007 158mm montys on 18:17, love it Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted June 19, 2007 Report Share Posted June 19, 2007 175........18:15........ How do you work that out that if you have shorter cranks you get more power. Longer cranks = more leverage = more force.i think ogre worked it out, if you have more leverage the gearing will be easier so you wont get the same power, it was something like that Quote Link to comment Share on other sites More sharing options...
JoNnY__Mc Posted June 19, 2007 Report Share Posted June 19, 2007 (edited) I run 170 with 18:15 gearing and I found when I tried to learn hooks the other week I clipped my pedal loads but I have 10+ bb so this could be why... Edited June 19, 2007 by JoNnY__Mc Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted June 19, 2007 Report Share Posted June 19, 2007 You run 170mm Jon. Deng echo cnc cranks only come in 170mm.I run 18:16 with 170mm Gu cranks.Danny. Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted June 19, 2007 Report Share Posted June 19, 2007 170mm Echo cranks 15T-18T gearing. Quote Link to comment Share on other sites More sharing options...
Deonn h Posted June 19, 2007 Report Share Posted June 19, 2007 You run 170mm Jon. Deng echo cnc cranks only come in 170mm.I run 18:16 with 170mm Gu cranks.Danny.same Quote Link to comment Share on other sites More sharing options...
Oskar Posted June 19, 2007 Report Share Posted June 19, 2007 175mm Tensile with 18:15 gearing Quote Link to comment Share on other sites More sharing options...
Janson Posted June 19, 2007 Report Share Posted June 19, 2007 175 tensile, 16:14. Quote Link to comment Share on other sites More sharing options...
Broomer Posted June 19, 2007 Report Share Posted June 19, 2007 175 burns with 22-18 Quote Link to comment Share on other sites More sharing options...
Tommy d Posted June 19, 2007 Report Share Posted June 19, 2007 170mm, 22:18, +10bb, but I'm not a hooker... Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted June 19, 2007 Report Share Posted June 19, 2007 i run 170 on my mod and stock and dont find a problem with either and i use 18-12 and for the stock i use 18-15 wich is realy nice but i want some middleburns there so nice . Quote Link to comment Share on other sites More sharing options...
eskimo Posted June 19, 2007 Report Share Posted June 19, 2007 If you have the money you might as well try something else out. You'd be suprised.Anyhow 18 - 15 rear Pro2 Quote Link to comment Share on other sites More sharing options...
gianttrials Posted June 19, 2007 Report Share Posted June 19, 2007 165mm midds 22:18 Quote Link to comment Share on other sites More sharing options...
shansen Posted June 19, 2007 Report Share Posted June 19, 2007 175 burns 18:16 Quote Link to comment Share on other sites More sharing options...
James-M Posted June 19, 2007 Report Share Posted June 19, 2007 Also 175 'Burns. Sssswishh. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted June 19, 2007 Report Share Posted June 19, 2007 170mm burns, 16:13 ratio.I think 16:14 is far too easy to be honest. My gapping drops by about a foot if i run that gear. Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted June 19, 2007 Report Share Posted June 19, 2007 175, 22-19 Quote Link to comment Share on other sites More sharing options...
hI-OOPS-CAPS Posted June 20, 2007 Report Share Posted June 20, 2007 175 tensiles, 20-17 Quote Link to comment Share on other sites More sharing options...
