ALEX@BIKETRIALSFUN Posted June 18, 2007 Report Share Posted June 18, 2007 HiThere are so many different ways of setting up a hs33 but what is the most effective way because doing it my way dose not seem to be working. So what is the most effective way of setting up a hs33 for a 4 bolt on the rear with a echo brake booster and green rock brake padsLet mo knowALEX Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted June 18, 2007 Report Share Posted June 18, 2007 Fully bled is a start............http://www.trials-forum.co.uk/wiki/How_to_...p_a_Magura_HS33Havent read it, but maybe you shold? Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted June 18, 2007 Report Share Posted June 18, 2007 Set you brake up properly by setting the pads up square to the rim and set out just right, this distance is normally the size of a two pence coin - and wind your tpa all the way in and away you go.Providing you have decent grind pads or decent smooth pads, you should have a great brake! Quote Link to comment Share on other sites More sharing options...
basher Posted June 18, 2007 Report Share Posted June 18, 2007 Set you brake up properly by setting the pads up square to the rim and set out just right, this distance is normally the size of a two pence coin - and wind your tpa all the way in and away you go.Providing you have decent grind pads or decent smooth pads, you should have a great brake!Wind the tpa off loosen mounts off and get something like a 2p coin and put it in between rim and pad tighten the bolts up. Do the same the other side and the pads will be square to the rim and equal distance from rim. Then as the pad wears down just wind the tpa on abit. Quote Link to comment Share on other sites More sharing options...
Boswell Posted June 19, 2007 Report Share Posted June 19, 2007 (edited) The other day i saw someone with their break set up on top of their booster. Dont no if it makes the break any better though. Edited June 19, 2007 by mr ? Quote Link to comment Share on other sites More sharing options...
ALEX@BIKETRIALSFUN Posted June 19, 2007 Author Report Share Posted June 19, 2007 The other day i saw someone with their break set up on top of their booster. Dont no if it makes the break any better though.On the top of their booster I have never seen that done before. Quote Link to comment Share on other sites More sharing options...
ALEX@BIKETRIALSFUN Posted June 21, 2007 Author Report Share Posted June 21, 2007 Hi I set my brakes up today because it was raining and tried the 2 pee idea and my rear brake most off all works lovely thanks everybody Quote Link to comment Share on other sites More sharing options...
