clarkytrials Posted June 18, 2007 Report Share Posted June 18, 2007 Hi I like the rise on my monty bars but that are just to Short and was wondering if any one nose where i will be able to get hold of some bar extenders ? Quote Link to comment Share on other sites More sharing options...
THE trials commentator Posted June 18, 2007 Report Share Posted June 18, 2007 Ali C had some i think,so he should help you,theres also someone on here that makes them,cant remember who though but Ali should be able to helpCarl Quote Link to comment Share on other sites More sharing options...
Has anyone seen my shoe? Posted June 18, 2007 Report Share Posted June 18, 2007 Ask Inur.Basically you make inserts into the end of your bars to extend them. Quote Link to comment Share on other sites More sharing options...
Matt_Tupman Posted June 18, 2007 Report Share Posted June 18, 2007 Whithurst did some a while back made from nylon I think but i'm not sure if theyre still going? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted June 18, 2007 Report Share Posted June 18, 2007 lmao, yeah ali was using wood haha Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted June 18, 2007 Report Share Posted June 18, 2007 I extended mine and they're holding up great. 29.5 inch Monty's...great width and geometry. Most ways of doing it are very makeshift. Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted June 18, 2007 Report Share Posted June 18, 2007 I could possibly make you some for like £10 or something but Edd Potts would probs do it cheaper and with a faster turn around... It's similar to a Quill system that I have in mind thats used in 1 inch headtubes. Quote Link to comment Share on other sites More sharing options...
Muel Posted June 18, 2007 Report Share Posted June 18, 2007 I just chopped off half an inch of bar from some old bars and wacked em on underneath the grips, held on with the bar plug.This wasn't my bike, and was a jump bike so I suppose you don't hold on as close to the ends of the bars as you do in trials. Quote Link to comment Share on other sites More sharing options...
Robwalker Posted June 18, 2007 Report Share Posted June 18, 2007 I could possibly make you some for like £10 or something but Edd Potts would probs do it cheaper and with a faster turn around... It's similar to a Quill system that I have in mind thats used in 1 inch headtubes.That would be a bad idea, they would just slip and fall out under enough pressure. Quote Link to comment Share on other sites More sharing options...
toyota200x Posted June 18, 2007 Report Share Posted June 18, 2007 I would love to see Ali's made of wood. Quote Link to comment Share on other sites More sharing options...
totaltrials Posted June 19, 2007 Report Share Posted June 19, 2007 I think motorbike shops might have some, there was a guy in Liverpool who got some from the local motorbike shop a few years ago though, real cheap, just plastic plugs that pushed into the ends of the bars.Worth a look/try anyway.Phil. Quote Link to comment Share on other sites More sharing options...
Muel Posted June 19, 2007 Report Share Posted June 19, 2007 I would love to see Ali's made of wood.You make your own, get some dowel, hammer it into the end of your bar until their is the right legnth sticking out then wrap tape round it until it is the same diameter as the bar, then wack your grips over the top. Quote Link to comment Share on other sites More sharing options...
clarkytrials Posted June 19, 2007 Author Report Share Posted June 19, 2007 nice one lads i will try a motorbike shop and if not i shall pm edd or ali c Quote Link to comment Share on other sites More sharing options...
ding_dong Posted June 20, 2007 Report Share Posted June 20, 2007 ODI lock-on grips, they have the rubber grip arround a metal tube wich if you don't push all the way onto the bars, would extend your bars.if that makes any sence, but if it doesnt i know it works, Quote Link to comment Share on other sites More sharing options...
RobinJI Posted June 20, 2007 Report Share Posted June 20, 2007 ODI's wouldn't quite work, because then there would only be one collar on the bar, causing them to rattle and get damaged. Also the middle of them's only thin plastic, not metal, and wouldn't really be safe to rely on. Although if you do use bar extensions ODI's would be a great way of making sure they were a bit more secure, and making sure you cant feel the transition between bar and extension. Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted June 20, 2007 Report Share Posted June 20, 2007 Whats wrong with using wood , ali and iolo both use wood.Matx Quote Link to comment Share on other sites More sharing options...
chrishayton Posted June 20, 2007 Report Share Posted June 20, 2007 Whats wrong with using wood , ali and iolo both use wood.Matxas do i and works perfectlyYou make your own, get some dowel, hammer it into the end of your bar until their is the right legnth sticking out then wrap tape round it until it is the same diameter as the bar, then wack your grips over the top.tut use a lathe. doing it your way would allow that extenders to slip into the bar if you crash and hit the end of the bar. sorry for double post Quote Link to comment Share on other sites More sharing options...
BONGO Posted June 20, 2007 Report Share Posted June 20, 2007 back in the day, people bought Renthal motocross bars @ 34" wide!!!!!!! I had a pair on my X stam hahahaIt was way more fun bodging and inventing. Now it's too easy, you got it all on a plate. I want DCD union jack chain guides, long bodied XC mech's, 12.5 Azonic frames and beasts of the east!!! Quote Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2007 Report Share Posted June 20, 2007 tut use a lathe. doing it your way would allow that extenders to slip into the bar if you crash and hit the end of the bar.Yeh, can't quite understand who kuelmuel think's he's helping with the advice he's given in this thread, two way's to injure oneself maybe????PM Inur, or else look in the topic he started for building up an adamant stock with 20" wheels, you will be able to find the thread from his profile. He has put up dimensioned drawings for extenders. Quote Link to comment Share on other sites More sharing options...
IOLO Posted June 20, 2007 Report Share Posted June 20, 2007 wood and nylon are fine.used a laithei will make some alu ones with expanding bolty end when i get round to it.iolo. Quote Link to comment Share on other sites More sharing options...
Muel Posted June 21, 2007 Report Share Posted June 21, 2007 Yeh, can't quite understand who kuelmuel think's he's helping with the advice he's given in this thread, two way's to injure oneself maybe????PM Inur, or else look in the topic he started for building up an adamant stock with 20" wheels, you will be able to find the thread from his profile. He has put up dimensioned drawings for extenders.Well funnily enough, I was trying to help the guy who started the thread! Imagine that. If it was wedged into the bar well enough and you were running closed ended grips and the extender was only 1" long then I can't see any way they could come out, it would only be your little fingers that would be on the end anyway.The wood would need to be a tight fit on the bar (obviously), I was just generating ideas. I have never used wood before.Personally I would make some metal ones with an expanding rubber wedge, but you have to also think of the extra weight hanging from the ends of your bars. Quote Link to comment Share on other sites More sharing options...
