bousfield19 Posted June 18, 2007 Report Share Posted June 18, 2007 hi everyone i have a hs33 on the rear with a deep ground rim i am running the koxx brown pads and i have done a fresh water bleed but my rear brake keeps slipping when pedal hopping anyone got any ideay why this is happening?any help would be greatly appreciatedmany thanks jamie Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 18, 2007 Report Share Posted June 18, 2007 may have contaminated your pads?pads may be set up shit?you got air in the system? Quote Link to comment Share on other sites More sharing options...
bousfield19 Posted June 18, 2007 Author Report Share Posted June 18, 2007 (edited) pads are brand new bought yesterday.spent about hour yesterday stripping it down and bleedin them in the bath making sure it was totally air freeand spent bout 30 mins setting them up yesterdayi will try to re bleed them today and see if there might be an air lock somewherethe thing is most of the time it works and locks fine but then every now and again just as i am starting to trust it again it just gives out and i end up on my ass lol Edited June 18, 2007 by bousfield19 Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 18, 2007 Report Share Posted June 18, 2007 i know its sounds stupid but how many grinds has that rim had?my bmf went all shitty after the last time i ground it.. Quote Link to comment Share on other sites More sharing options...
Boswell Posted June 18, 2007 Report Share Posted June 18, 2007 (edited) Maybe you have set your pistons up too far away from the rim. Edited June 18, 2007 by mr ? Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 18, 2007 Report Share Posted June 18, 2007 Maybe you have set your pistons up too far away from the rim.i think thats insulting his intelligence. Quote Link to comment Share on other sites More sharing options...
bousfield19 Posted June 18, 2007 Author Report Share Posted June 18, 2007 i dont know how many grinds its had as i have only just got the bikei have just re ground the rim as it had what looked like tar on it as well so i have cleaned that off cleaned my pads off and re bled the system with water and re set it all up and now it seems to be working but im off for a ride now so will let you know if the problem still existsthanks for all your helpjamie Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted June 18, 2007 Report Share Posted June 18, 2007 white spirt the rim, get all the crap off the rim, file to new material on pads, regring, tar, sorted Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 18, 2007 Report Share Posted June 18, 2007 white spirt the rim, get all the crap off the rim, file to new material on pads, regring, tar, sorted you dont need tar.if he's just put a new grind on it doesnt need cleaning.just thought, maybe the pads need to be bed in some more? how long have you riden on them? Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted June 18, 2007 Report Share Posted June 18, 2007 you dont need tar.if he's just put a new grind on it doesnt need cleaning.just thought, maybe the pads need to be bed in some more? how long have you riden on them?yer bed them in first, there new! Quote Link to comment Share on other sites More sharing options...
Krisboats Posted June 18, 2007 Report Share Posted June 18, 2007 i know its sounds stupid but how many grinds has that rim had?my bmf went all shitty after the last time i ground it..Please tell me you weren't trying to imply that the brake gets worse after your rims been ground a few times. Thats just retarded.I think the solution is pretty clear. Get some sandpaper and just take the edge off your grind a bit. I'll bet you've given a nice beasty deep grind... which can give a good hold, but get some force behind it and it'll shave material off your pads rather than letting them grip. Sandpaper the edge off, only needs a little rub all the way round the rim and i'm pretty sure you'll find your pads get their act together. Quote Link to comment Share on other sites More sharing options...
max-t Posted June 18, 2007 Report Share Posted June 18, 2007 set the pads up square to the rimmake sure they both hit the rim at the same timeset them up as close as possible without them rubbingmake sure they are clean and worn straitadjust the tpa all the way off so that the pads are sitting as far into the slave cylinder as possible.grind the rim in the same direction on both sides (anticlockwise) Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 18, 2007 Report Share Posted June 18, 2007 Please tell me you weren't trying to imply that the brake gets worse after your rims been ground a few times. Thats just retarded.no, i was trying to say that my bmf was flexing over and making my brake shit because it had too many grinds. Quote Link to comment Share on other sites More sharing options...
bousfield19 Posted June 18, 2007 Author Report Share Posted June 18, 2007 well doing the regrind and sanding the new pads as well as the water bleed has made a load of difference. The rear brake is really grippy now . thanks for all the help.I have just had a nice ride with a couple of mates and my god im aching all over serves me right for not riding for 3 years Quote Link to comment Share on other sites More sharing options...
BRISA RIDER! Posted June 19, 2007 Report Share Posted June 19, 2007 pads are brand new bought yesterday.spent about hour yesterday stripping it down and bleedin them in the bath making sure it was totally air freeand spent bout 30 mins setting them up yesterdayi will try to re bleed them today and see if there might be an air lock somewherethe thing is most of the time it works and locks fine but then every now and again just as i am starting to trust it again it just gives out and i end up on my ass lolIf pads were bought brand new yesterday they're bound not to work as pads need a beading in time! pads roughly take 3 to 5 days of riding before they perform 100%. Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 19, 2007 Report Share Posted June 19, 2007 If pads were bought brand new yesterday they're bound not to work as pads need a beading in time! pads roughly take 3 to 5 days of riding before they perform 100%.it took my plazzies a minute to bed intook my phat pads about 5 minutes to bed in.don't know where you got 3 to 5 days from. Quote Link to comment Share on other sites More sharing options...
BRISA RIDER! Posted June 19, 2007 Report Share Posted June 19, 2007 it took my plazzies a minute to bed intook my phat pads about 5 minutes to bed in.don't know where you got 3 to 5 days from.Depends what pads your running! its obvious that plasmatics are going to bed in within a day, because they only last about a month.3-5 days on a smooth rim rims with a grind OK maby 2 days. Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted June 19, 2007 Report Share Posted June 19, 2007 it took my plazzies a minute to bed intook my phat pads about 5 minutes to bed in.don't know where you got 3 to 5 days from.koxx browns are a harder material to them, therefore take longer to bed inbut dont go dragging your brake constantly,just go down a hill and pull it on off, if you get me. dont drag it all the way down... Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 19, 2007 Report Share Posted June 19, 2007 Depends what pads your running! its obvious that plasmatics are going to bed in within a day, because they only last about a month.3-5 days on a smooth rim rims with a grind OK maby 2 days.plazzies last about 6 monthsphat pads are a hard compound and don't take long to bed in. Quote Link to comment Share on other sites More sharing options...
mitchy-boy123 Posted June 19, 2007 Report Share Posted June 19, 2007 I would not listen to them all you need to do really is clean down your rim and use a bit of tar making sure you spread it the whole way round your rim then it should be fine lol.from mitch. Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 19, 2007 Report Share Posted June 19, 2007 I would not listen to them all you need to do really is clean down your rim and use a bit of tar making sure you spread it the whole way round your rim then it should be fine lol.from mitch.tar? wtf?grind ***tar ftlsimple as, tar is used when you cant afford decent pads. Quote Link to comment Share on other sites More sharing options...
BRISA RIDER! Posted June 19, 2007 Report Share Posted June 19, 2007 Iv seen loads of lads do that. they buy new pads then wack them on a tard rim, the first big gap they do they end up taking chunks out there pads! simply because the pad compound needs to bed in!!!! .DANNY MACASKIL IS A GOD. Quote Link to comment Share on other sites More sharing options...
