paul@rettotrials Posted June 18, 2007 Report Share Posted June 18, 2007 well like it says i need to build a onza t-master hub on to a 32 hole onza hog rim any help would be very helpful and/or a link to a website that has pics and tells you how to do it thanks. paul. Quote Link to comment Share on other sites More sharing options...
The Duck Posted June 18, 2007 Report Share Posted June 18, 2007 Been there, done that and balls'd it up. Basically I'd send it to tarty because the chances of doing it right, are next to none. Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted June 18, 2007 Report Share Posted June 18, 2007 (edited) paul@rettotrials said: well like it says i need to build a onza t-master hub on to a 32 hole onza hog rim any help would be very helpful and/or a link to a website that has pics and tells you how to do it thanks. paul.stick it in the post to me along with a fiver and i'll build it for you! i've built loads of wheels where the hub and rim have different number of holes and they've all been really fine!edit:pm me for my adress if you want to post it to me! Edited June 18, 2007 by samdoman Quote Link to comment Share on other sites More sharing options...
The Duck Posted June 18, 2007 Report Share Posted June 18, 2007 samdoman said: stick it in the post to me along with a fiver and i'll build it for you! i've built loads of wheels where the hub and rim have different number of holes and they've all been really fine!edit:pm me for my adress if you want to post it to me!How?! Do tell... Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted June 18, 2007 Report Share Posted June 18, 2007 Quackers said: How?! Do tell...mark two holes opposite eachother on one flange of the hub and on the other flange mark two oposite holes but rotated 90degrees relative to the other flange if you understand what i mean? then just build it as normal skipping out these holes!!it's not too much of a problem when the hub has more holes, it's worse the other way round as the tension isn't spread evenly around the rim.i'm the wheelbuilder at the bike shop where i work, and i've come across plenty of builds like this! Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted June 18, 2007 Report Share Posted June 18, 2007 Think of the rim as a clock.Miss out the 12 o clock hole, 3 o clock hole, 6 o clock hole and the 9 o clock hole. Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted June 18, 2007 Report Share Posted June 18, 2007 This is stupid, and it'll end up a naff wheel whoever builds it.Why not get hold of a rim with 36 holes? In the long run it'll be a lot better... Quote Link to comment Share on other sites More sharing options...
paul@rettotrials Posted June 18, 2007 Author Report Share Posted June 18, 2007 thanks for all the help me and my friend have now built it up and to say its are first go at a wheel build it is mint. Quote Link to comment Share on other sites More sharing options...
