Rob Brodie Posted June 17, 2007 Report Share Posted June 17, 2007 hey guys im havin problems with my new green hs 33 and i just wondered if anyone one else has? Quote Link to comment Share on other sites More sharing options...
gianttrials Posted June 17, 2007 Report Share Posted June 17, 2007 hey guys im havin problems with my new green hs 33 and i just wondered if anyone one else has? what kind of problem? be more specific if you want help Quote Link to comment Share on other sites More sharing options...
Rob Brodie Posted June 17, 2007 Author Report Share Posted June 17, 2007 yh the tpa went on it then i got the levers switched but now when u pull the lever one of the pads doesnt come back out and just rubs. also the crossover goes from top to botom not bottom to bottom Quote Link to comment Share on other sites More sharing options...
gianttrials Posted June 17, 2007 Report Share Posted June 17, 2007 maybe u should take it back to the shop u bought it from? (when u say lever do u mean the lever blade or the whole lever body? because lever blades are the same left/right), alternatively u may need to try a re-bleed an sounds like tubing needs re-fitting. if u can re-fit it do a water bleed (or bath bleed if u dont have a bleed kit) an remove the pads an try abit of gt-85 on the seals of the sticky piston to see if it stops it seizing.hopefully that should make sense an work for uben g WST Quote Link to comment Share on other sites More sharing options...
ConnorPowell Posted June 17, 2007 Report Share Posted June 17, 2007 Sounds like you have take the lever blade out and when you have put it back in you have overtightened it so try loosening it off,also the tpas sound like they have gone get some 74kingz metal ones from tartybikes. Cheers Connor Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted June 17, 2007 Report Share Posted June 17, 2007 hey rob.get andy to switch the crossover pipe around........and im shure he will sort you out a water bleed.....and post some pics up of ur sexy fooking bike Quote Link to comment Share on other sites More sharing options...
Rob Brodie Posted June 17, 2007 Author Report Share Posted June 17, 2007 cheers guys Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 17, 2007 Report Share Posted June 17, 2007 i just saw a picture of it and saw you had braided hose...i had a problem where i had a slow leak, but tightened all the fixings up and its fine now, maybe try this? Quote Link to comment Share on other sites More sharing options...
Boswell Posted June 17, 2007 Report Share Posted June 17, 2007 You may have slow pistons, take the pads of the break pull the lever to make the pistons pop out and spray a lube like for example wd40 on them and that should sort the problem . Quote Link to comment Share on other sites More sharing options...
