Onza-Trials Posted June 17, 2007 Report Share Posted June 17, 2007 my hs33 rear keeps on braking.the lever and over bit near the lever keeeps snapping i think because when i pull it in hard for a drop it makes a loud noise and then i can pull the lever all the way in to the grips and it doesnt stop me? how do i get rid of this prblem i keep buying new lever but happens again. Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 17, 2007 Report Share Posted June 17, 2007 got a leak? loljust pull your lever really hard and see if water/oil comes out anywherei had this problem because my mate didnt tighten up all the fittings... Quote Link to comment Share on other sites More sharing options...
gu_lew Posted June 17, 2007 Report Share Posted June 17, 2007 got a leak? loljust pull your lever really hard and see if water/oil comes out anywherei had this problem because my mate didnt tighten up all the fittings...It is most likely a leak but if not try playing around with your tpa or you might be over tightening the bolt that keeps the lever blade on the lever. Quote Link to comment Share on other sites More sharing options...
ConnorPowell Posted June 17, 2007 Report Share Posted June 17, 2007 You haven't bought as new lever yet and its probably the plunger inside the lever body so i would say get a new lever body.Also use the spell check its there for a reasonCheers Connor Quote Link to comment Share on other sites More sharing options...
Muel Posted June 17, 2007 Report Share Posted June 17, 2007 (edited) my hs33 rear keeps on braking.I would be very worried if my hs33 stopped braking, but on reading the rest of this topic I realised you meant breaking.It sounds like your TPA could be packing in, get a metal one. It is hard to know what you mean from what your describing.You haven't bought as new lever yet and its probably the plunger inside the lever body so i would say get a new lever body.Also use the spell check its there for a reasonCheers ConnorYou need to use the spell checker as well mate. It is probably not the plunger inside the lever body, these are made of metal, whereas the TPA is made of plastic, unless it hasn't been upgraded to metal.Take some pics, it might help us to realise what your trying to tell us. Edited June 17, 2007 by KuelMuel Quote Link to comment Share on other sites More sharing options...
gianttrials Posted June 17, 2007 Report Share Posted June 17, 2007 yep could be the tpa (if its a new shape lever), they do have a tendency i found of stripping the inner threads and making the lever pull right bar to the bars, once they start going like that you should notice a light bang kinda noise when you pull back and the tpa will look like its a weird angle (when looking at it straight on), if this is the case try re-fitting/alligning the tpa on the thread or buy a new lever blade (as said above maybe a metal one)ben g WST Quote Link to comment Share on other sites More sharing options...
Onza-Trials Posted June 19, 2007 Author Report Share Posted June 19, 2007 You haven't bought as new lever yet and its probably the plunger inside the lever body so i would say get a new lever body.Also use the spell check its there for a reasonCheers Connoractually i have brought a new whole lever and still brakes you no what i buy and dont bit wierd Quote Link to comment Share on other sites More sharing options...
ConnorPowell Posted June 19, 2007 Report Share Posted June 19, 2007 Woody i ride with you i think i should know when you have brought something new for your bike Quote Link to comment Share on other sites More sharing options...
BRISA RIDER! Posted June 19, 2007 Report Share Posted June 19, 2007 You haven't bought as new lever yet and its probably the plunger inside the lever body so i would say get a new lever body.Also use the spell check its there for a reasonCheers Connorwhats spelling got to do with trials mate!!!! the lads got a problem an he has asked opinions how to fix it.he never asked for a opinion on his spelling. i thought it was quite clever spelling breaking as braking it grabbed my attentionBut it does sound like your leaver body needs to be changed though mate. Quote Link to comment Share on other sites More sharing options...
Onza-Trials Posted June 19, 2007 Author Report Share Posted June 19, 2007 Woody i ride with you i think i should know when you have brought something new for your bike connor i havnt rode with you for 2 weeks i can easily buy something off tarty bikes with out you having to no??? Quote Link to comment Share on other sites More sharing options...
