Alex.loves.boys Posted July 12, 2006 Report Share Posted July 12, 2006 Hi guys got a issue i've taken the headset outta my monty there two cups a top one and a bottom one the top one just slots in but the bottom seams to large. does this mean i need a headset press or will it not fit at all by the way the its an "aheadset" i don't see why i wont fit there both the same type of headset. any help would be aprieceated Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted July 12, 2006 Report Share Posted July 12, 2006 frame secondhand? could be flared... Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted July 12, 2006 Author Report Share Posted July 12, 2006 frame secondhand? could be flared...doubt iti ran the frame before, then sold it and everything was fine then Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted July 14, 2006 Author Report Share Posted July 14, 2006 can someone please help me Quote Link to comment Share on other sites More sharing options...
Guest Posted July 14, 2006 Report Share Posted July 14, 2006 (edited) The cups that go into the frame should not just 'fit in' they should be pressed using a headset tool otherwise you'll run the risk of flaring the HT as paul said.Just because it wasn't flared when you had it, doesnt mean a twat hasn't had their way with it since.If your asking you really shouldn't be messing with such thing's.Is it the same headset you used before? When you sold the bike did you remove your original headset I guess? and is it the same headset you now wan't to fit? Didn't you notice when removing it in the first instance that it was pressed in, and you would have had to whack it out?Regardless, you havn't given a good description as to the problem really, hence my shite reply. Edited July 14, 2006 by jake1516 Quote Link to comment Share on other sites More sharing options...
poopipe Posted July 14, 2006 Report Share Posted July 14, 2006 what's this got to do with a t-pro?you wont get a normal headset into a t-pro on account of it being the wrong kind Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted July 15, 2006 Report Share Posted July 15, 2006 what's this got to do with a t-pro?you wont get a normal headset into a t-pro on account of it being the wrong kindChildren ey? Quote Link to comment Share on other sites More sharing options...
joe b Posted July 16, 2006 Report Share Posted July 16, 2006 Monty use the same headset as a T-Pro. So, he isn't trying to fit a standard headset into a T-Pro, because that would be ludacris. He is, as it clearly states, trying to get the right sized headset into the right sized frame! If i were you, Alex. Take it down to your local bike shop, and ask them to install the headset for you; i'm sure they will possess a headset press... Cheers,Joe. Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted July 17, 2006 Author Report Share Posted July 17, 2006 -->QUOTE(joe b @ Jul 17 2006, 12:08 AM) ←Monty use the same headset as a T-Pro. So, he isn't trying to fit a standard headset into a T-Pro, because that would be ludacris. He is, as it clearly states, trying to get the right sized headset into the right sized frame! If i were you, Alex. Take it down to your local bike shop, and ask them to install the headset for you; i'm sure they will possess a headset press... Cheers,Joe.this kids got it it's all done now the bottom headset cup had a bearing race thing in it ah well Quote Link to comment Share on other sites More sharing options...
Guest Posted July 17, 2006 Report Share Posted July 17, 2006 Still havn't a clue as to what the problem was, but glad you got it fixed. Quote Link to comment Share on other sites More sharing options...
