Mr Motivator Posted May 8, 2006 Report Share Posted May 8, 2006 How?Help?Sam Quote Link to comment Share on other sites More sharing options...
mat hudson Posted May 8, 2006 Report Share Posted May 8, 2006 hit them with a mallet and a screwdriver or somthing like that. Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted May 8, 2006 Author Report Share Posted May 8, 2006 What just tap both of them out from the inside?It's not happening. I think they are pressed in. Hmmn. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted May 8, 2006 Report Share Posted May 8, 2006 ye, so press em back out, hit harder poooosaaayyyy Quote Link to comment Share on other sites More sharing options...
TheMunn Posted May 8, 2006 Report Share Posted May 8, 2006 ye, so press em back out, hit harder poooosaaayyyy tongue.gifHahaa... Basically yeah, they are pressed in, but if you hit them hard enough they will come out. Just give it some beans. Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted May 8, 2006 Author Report Share Posted May 8, 2006 I gave it pasty, they didn't move. I hit it so hard, the hammer hammer of the rod thing im using to hit against and i whacked my finger and now I'm in pain. Ow. Quote Link to comment Share on other sites More sharing options...
shovel Posted May 9, 2006 Report Share Posted May 9, 2006 as said above they should hammer out, to fit the new ones you should use the hope drift set to get the bearings pressed in square to prevent uneven wear, local bike shop should have a hope drift set.if you're having too much trouble with it, send it back to hope and get them to do it Quote Link to comment Share on other sites More sharing options...
Nick Harding Posted May 9, 2006 Report Share Posted May 9, 2006 use a socket head so you dont munt them Quote Link to comment Share on other sites More sharing options...
rich4130 Posted May 9, 2006 Report Share Posted May 9, 2006 (edited) No no no no no!!There is a circlip preventing the bearings from coming out, you need to knock it to the side and then remove the bearing to get them out, theres a diagram on the hope site.No amount of twatting will get em out!EDIT: hit the aluminuim spacer between the bearings to one side, been a while since I done this.. Edited May 9, 2006 by rich4130 Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted May 9, 2006 Author Report Share Posted May 9, 2006 No no no no no!!There is a circlip preventing the bearings from coming out, you need to knock it to the side and then remove the bearing to get them out, theres a diagram on the hope site.No amount of twatting will get em out!EDIT: hit the aluminuim spacer between the bearings to one side, been a while since I done this..Ah!!So, move the spacer accross, and hit the spacer to get the first bearing out? Then take off the circlip for the second?Sam Quote Link to comment Share on other sites More sharing options...
Waynio Posted May 9, 2006 Report Share Posted May 9, 2006 well done rich!!!!so funny listening to people just say "smash" it with a hammer!!!! when people dont know how to do it. i say this is the thread i can say, the POOR advise from some members can be the mis fortune of someone trying to repair their bike.i would say this, if you dont know how to do it, DONT go giving BAD advise on telling someone to bash it out, good advice comes for free, advie that the top few posts have given are bad and could cost a fellow trials rider some £££!!!!Rich well played your totally right, you must work in a bike shop??? or have good knowledge of hope hubs.if you get the bearing nearset the end out you can sort of see the circlip as the "spacer" washer will fall out. just please be careful. you could have ruined your freehub over someones BAD/POOR adviceWaynio........................ Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted May 9, 2006 Report Share Posted May 9, 2006 Agree with Waynio here, could of been at least £35 down the drain due to someone saying the first thing that came to their head, the way i see it is, if you haven't done it, dont tell other people how to. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted May 9, 2006 Report Share Posted May 9, 2006 to be honest, thats how most of the hope stuff works so i just thought, twat it, he didnt tell us there was a circlip Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted May 9, 2006 Author Report Share Posted May 9, 2006 Ok, got one out, now how do i get the circlip off?? Quote Link to comment Share on other sites More sharing options...
Waynio Posted May 9, 2006 Report Share Posted May 9, 2006 you need a pincer tool.so you can "compress" the circlip together then pull it out, press the bearing out, then put the new bearing in, NOT FORGETTING to put the circlip back in. Waynio.......................if your struggling give me a bell on 01535 610839 il talk you through it dude. just ask for Wayne. Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted May 9, 2006 Author Report Share Posted May 9, 2006 Well, I'm compressing it with a pair of long nose pliers, but I cant get enough grip on it to pull it out. Hmmmmn.Cheers though Wanye Quote Link to comment Share on other sites More sharing options...
Waynio Posted May 9, 2006 Report Share Posted May 9, 2006 if you know a local tool shop some long nose "pincers" or something that will get down the freehub bore and get into the 2 little holes it just needs compressing THEN pulling a little bit and quite slow too.once half way out you can just pull it out with a screw driver. but dont try putting it back in without the circlip going in. the hub will lock up and not run as it should.Waynio.........................for that matter IS it the back bearing thats knakered???? cos sometimes its only one or two of the bearings that is knakerd??? if its stiff or rough then yes its worth replacing, but it may be rough with you having a "bash" at it check it 1st and see, you might get away with just replacing the other bearings.Waynio................... Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted May 9, 2006 Author Report Share Posted May 9, 2006 Neither are knackered, I just need it out to take some measurements.Still trying with these pliers. Grr. Just can't get enough grip. Quote Link to comment Share on other sites More sharing options...
Danny Posted May 9, 2006 Report Share Posted May 9, 2006 Maplin sell a set of circlip plyers for a fiver which mite make life easier Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted May 9, 2006 Author Report Share Posted May 9, 2006 Got the bugger. Finally!!I used a vice as a spare hand to hold the freehub, then used two hands on the pliers that I filed dow to fit perfectly in the holes, then ground the pliers for more grip.Jobs a good un Cheers all. Quote Link to comment Share on other sites More sharing options...
Waynio Posted May 9, 2006 Report Share Posted May 9, 2006 ye those are em that danny posted we use literally that set @ work.glad you got it sorted dude Waynio.......................OH and remember DONT jump in 2 footed and BASH stuff, there is a simple and quicker more technical way of doing things than "bashing it with a hammer" Quote Link to comment Share on other sites More sharing options...
