bikespace Posted May 1, 2006 Report Share Posted May 1, 2006 Hi all,I have a Monty frame with a duff thread on the front bolt of the sump guard. Any advice? Is helicoil the best way to sort it out? Can you buy them in small quantities? Are they easy to do, or would I be better to just shove it in to a shop and have done with it.Cheers Quote Link to comment Share on other sites More sharing options...
lee220 Posted May 1, 2006 Report Share Posted May 1, 2006 Just tap it out with a tap and die set, you shouldn't need to helicoil it. Quote Link to comment Share on other sites More sharing options...
thread repair Posted March 6, 2007 Report Share Posted March 6, 2007 Hi all,I have a Monty frame with a duff thread on the front bolt of the sump guard. Any advice? Is helicoil the best way to sort it out? Can you buy them in small quantities? Are they easy to do, or would I be better to just shove it in to a shop and have done with it.Cheerstry wti fasteners, no minimum order charge. kits around £22 Quote Link to comment Share on other sites More sharing options...
