Wheres My Tasktray Icon Gone?
PaRtZ
Everytime I close Azureus, the option is set to minimize to the tasktray (the bit by the clock, bottom right) But Everytime I do close it, its not there :S and im not completly n00blike, I've clicked the arrow and its not there either
Ideas?
Also its just done it now as if to remind me, You know when you turn your computer off, it makes a small beep inside the computer tower itself? Well my keeps on doing that, then making the whirring/loading noises that it would if it were restarting :S. It doesn't ALWAYS do this, infact its stopped now, but sometimes it can only beep once, other times non stop.
Again any ideas? Will give more info if wanted
Thanks in advance
does it beep at startup ? apart from the 'im a healthy happy computer' beep its supposed to make
beeps generally mean bad things but i wouldnt panic unless the machine starts turning itself off or refusing to turn on - its probably something to do with the wanky software/windows being gay
as for the software - i'd say take it off and put it back again, see if that sorts it.
whats the machine made of? mobo, cpu, memory disks etc . if it makes stupid noises at startup let me know what sort of beeps they are and what kind of bios you have - ill try to find out the codes
  Krisboats said:
Mine used to make one beep when i turned it on.
then i got a new graphics card and motherboard and it made two beeps.
then i updated the bios on the motherboard and it now makes three beeps.
Still works fine though.
:S
Mine randomly beeps once but aparently thats the mobo clock dying, hasnt reset randomly in like several days now (Y) *touches wood*
Edited by pinky@shitbmx
