Removing My Fixed Cog. :(
IOLO
help i cant get my fixed cog off my tensiles!!!!!
what can i do,,
ive tried a chain whip with crank in vice..
i then extended the chain wip with a steel tube,, but this bent my chain whip.
so i made a new one from a long steel box tube.. but this time the chain pressed into the tube wall loads.. iv tried heating it a little,,(kettle),, and iv but WD40 all over it.
grrrr help !
im considering cutting the cog off.. but it did cost £18. and its nice powder coated steel.
Bash the lot in a freezer.
Boil kettle.
Pour a tiny bit of boiling water on the sprocket, to heat it (and only it) up.
Get some blocks of wood, clamp the sprocket as hard as you can in a nicely fixed down vice.
Bash the end of the crank arm - the 'shock' will help to release it.
Release agent, like Plusgas, may help.
Good luck!
I'm not sure how effective this will be, but cooling the whole lot down might help, the alloy of the crank should shrink more than the steel cog. Worth a whirl before you break out the angle grinder anyway :)
EDIT: f**k me i get slower by the day :">
Edited by dave85
its ok,, scenario over!!
ye freezer,,, then kettle on steel. then wack..
JUST, did it.
what i kafufle
thanks every 1 for quik replys.
really is good when your stuck and you can get some more oppinions online and sort a job, all in about 15 mins..
thanks
Edited by IOLO
At work, I used a Var Chain whip, its about 1 and a half foot long, clamped that into a bike jig then used a nail and some zip ties to hold the cog/wheel in the whip. then a mate and i literally unscrewed it using the leverage of the wheel. any halfords should be able to do it.
tom
