tryallmaster Posted March 17, 2010 Report Share Posted March 17, 2010 (edited) The awesome power of LGM is now available off the shelf for vee brake's. In the form of the LGV MK 2. The pads have been put through their paces by Ali C for the past couple of months. TNN have just shipped their first order out this week so they should be available in the next week or so. Now the news that has been a long time coming... a new TNN compound. Claimed by no other than Kenny Belaey. The Pro Belaey Blue pads are still going through final testing but looks to have all the making to live up to their big brother the LGM. Kenny's first impressions of the pads are extremely positive. A very promising sign from one of the world's highest ranking riders. Attached are the pictures of the LGV'S and Pro Beleay Blue pads. What do you think guys? Cheers, Lewis. LGV MK 2 Pro Beleay Blue Pads Edited March 17, 2010 by tryallmaster Quote Link to comment Share on other sites More sharing options...
bigamac Posted March 17, 2010 Report Share Posted March 17, 2010 The pads have been put through their paces by Ali C for the past couple of months. Not trying to sound like a tw*t, but ali c has been riding brakeless? Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted March 17, 2010 Report Share Posted March 17, 2010 More than one bike? Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted March 17, 2010 Report Share Posted March 17, 2010 I'm loving the chamfered edges! Great to see that coming as standard now. Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted March 17, 2010 Report Share Posted March 17, 2010 (edited) Sounds like TNN are trying to compete against Rockman cnc blue pads which have the best hold at the mo, unless steve@heatsink gets in on the cnc act with cnc red. Edited March 17, 2010 by Rusevelt Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 17, 2010 Report Share Posted March 17, 2010 Oooh, if these new Beleay pads are any good might have to get some refills. What sort of set up are the Vee pads designed for? Grind? Smooth? Etc. Quote Link to comment Share on other sites More sharing options...
Ali C Posted March 17, 2010 Report Share Posted March 17, 2010 had the vee pads on my inspired before I went brakeless and I also have them on my comp bike. They actually work pretty well on a smooth rim but are ideally suted for a light sharp grind. They have loads of bite! More so than most other pads I have used, but they also have great hold. They are pretty thin too, so it makes setting up brakes with wide rims easier. Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 17, 2010 Report Share Posted March 17, 2010 had the vee pads on my inspired before I went brakeless and I also have them on my comp bike. They actually work pretty well on a smooth rim but are ideally suted for a light sharp grind. They have loads of bite! More so than most other pads I have used, but they also have great hold. They are pretty thin too, so it makes setting up brakes with wide rims easier. Ideal, so with a dead grind they might have a little more modulation at the small sacrifice of hold and bite? Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted March 17, 2010 Report Share Posted March 17, 2010 Ideal, so with a dead grind they might have a little more modulation at the small sacrifice of hold and bite? Yes. My grind is dead atm and my LGMs swoosh then hold well. As apposed to honk and grip with ease on a light sharp grind, like Ali says. Quote Link to comment Share on other sites More sharing options...
ogre Posted March 17, 2010 Report Share Posted March 17, 2010 whats the wear life on LGMs like? Quote Link to comment Share on other sites More sharing options...
ben_travis Posted March 17, 2010 Report Share Posted March 17, 2010 (edited) really cr*p.......they just WONT wear down....i have been trying for months p.s. could someone provide some justification regarding the chamferred edges? benefits, downfalls, reasons etc? kenny must have had some reason for asking for the pads to be the way they are....just intrigued Edited March 17, 2010 by ben_travis Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 17, 2010 Report Share Posted March 17, 2010 p.s. could someone provide some justification regarding the chamferred edges? benefits, downfalls, reasons etc? kenny must have had some reason for asking for the pads to be the way they are....just intrigued I'm 90% sure that it reduces noise. Is the wear life better than the 1st ones then? As it was shocking before! Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 17, 2010 Report Share Posted March 17, 2010 If you mean wear life of the LGMs, then the compound's the same so it should be fine. You really have to set them up perfectly otherwise they will wear relatively quickly, but spending a few seconds longer making sure your pads are perfectly lined up is a bit better than having to buy pads more frequently. You'll also get a better performing brake to boot. The only problems with fast wearing LGMs or LGVs seem to be where people cut corners with setup. The classic "This grind hasn't worked instantly, I must regrind it!" thing doesn't help either... Quote Link to comment Share on other sites More sharing options...
Oli P Posted March 17, 2010 Report Share Posted March 17, 2010 (edited) Finally a good set of backings that have the counter sink in them to reduce the number spacers needed instead of making my own. Are the shafts on the LGV backings steel or aluminum? Edited March 17, 2010 by Oli P Quote Link to comment Share on other sites More sharing options...
Le @ Tnn Engineering Posted March 18, 2010 Report Share Posted March 18, 2010 Finally a good set of backings that have the counter sink in them to reduce the number spacers needed instead of making my own. Are the shafts on the LGV backings steel or aluminum? 12.5 grade high tensile steel. really cr*p.......they just WONT wear down....i have been trying for months p.s. could someone provide some justification regarding the chamferred edges? benefits, downfalls, reasons etc? kenny must have had some reason for asking for the pads to be the way they are....just intrigued Travis The chamfers on the pads help to stop uneven wear plus give a little extra power. (more pressure per area) Some will disagree. Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 18, 2010 Report Share Posted March 18, 2010 The chamfers on the pads help to stop uneven wear plus give a little extra power. (more pressure per area) Some will disagree. That 'extra power' is only going to last for a relatively short period though before the pad wears down to a wider point? Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted March 18, 2010 Report Share Posted March 18, 2010 That 'extra power' is only going to last for a relatively short period though before the pad wears down to a wider point? It wont be a short period of time if you take a few more seconds to set your pads up right. Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 18, 2010 Report Share Posted March 18, 2010 As soon as they wear at all you're increasing the contact area though, so that first power won't theoretically be the same. Nice try though Ross Quote Link to comment Share on other sites More sharing options...
ben_travis Posted March 18, 2010 Report Share Posted March 18, 2010 (edited) As soon as they wear at all you're increasing the contact area though, so that first power won't theoretically be the same. Nice try though Ross however the point at which the chamfer is the same surface area as a standard square pad, there will be no usable pad anyway. so essentially le is suggesting more 'power' than a standard square pad. also due to the nature in which a standard pad becomes mis shapen (rounding corners etc) then even more power in the new KBM's compared to a standard shaped pad...possibly? ill wait to try some. however the LGMs are amazing anyway, so this new material will have to be something special. EDIT: i love the way kenny has his name engraved on his backings. awesome. plus extra weight saving Edited March 18, 2010 by ben_travis Quote Link to comment Share on other sites More sharing options...
mr kenny Posted March 18, 2010 Report Share Posted March 18, 2010 however the point at which the chamfer is the same surface area as a standard square pad, there will be no usable pad anyway. so essentially le is suggesting more 'power' than a standard square pad. also due to the nature in which a standard pad becomes mis shapen (rounding corners etc) then even more power in the new KBM's compared to a standard shaped pad...possibly? ill wait to try some. however the LGMs are amazing anyway, so this new material will have to be something special. EDIT: i love the way kenny has his name engraved on his backings. awesome. plus extra weight saving Gutted, i wish they had kenny engraved on the back, i'd buy another pair just for that:) Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted March 18, 2010 Report Share Posted March 18, 2010 Gutted, i wish they had kenny engraved on the back, i'd buy another pair just for that:) So the KBMs (Travis you name stealing b*****d ) all come with backings with "Beleay" engraved on them, or is that just Pro rider pimp'ness? Quote Link to comment Share on other sites More sharing options...
mr kenny Posted March 18, 2010 Report Share Posted March 18, 2010 So the KBMs (Travis you name stealing b*****d ) all come with backings with "Beleay" engraved on them, or is that just Pro rider pimp'ness? If thats the case i want to start a petition to get greenhalgh on the rears of lgm's! lol Quote Link to comment Share on other sites More sharing options...
tryallmaster Posted March 20, 2010 Author Report Share Posted March 20, 2010 If thats the case i want to start a petition to get greenhalgh on the rears of lgm's! lol I think have green on the left pad and have halgh on the right - its too long otherwise! haha Kenny on the pads would be pretty sweet though!!! Quote Link to comment Share on other sites More sharing options...
aener Posted March 20, 2010 Report Share Posted March 20, 2010 Super cool! Why not get his face etched into the backings, too! Seriously... Are they his signature backings? Look like regular TNNs to me. Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 25, 2010 Report Share Posted March 25, 2010 Couple of different angles of the LGVs for those who wanted to see more: Quote Link to comment Share on other sites More sharing options...
