josh barker Posted December 19, 2009 Report Share Posted December 19, 2009 hi, i have currently built up my limey 320 and the chain is rubbing on the seatstay, can isolve this by putting washers on the axle.my bb is a 127.5 is this to wide for the chainline on my frame?help appreciated, josh Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 19, 2009 Report Share Posted December 19, 2009 What gearing are you running? Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 19, 2009 Author Report Share Posted December 19, 2009 What gearing are you running? 18-12standard mod gearing,the chain is way out of line Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 19, 2009 Report Share Posted December 19, 2009 18-12standard mod gearing,the chain is way out of lineThat's a bit weird. I guess if you can get away with changing the BB length then that would help but 127.5/128mm is pretty much standard for ISIS these days anyway. How does the spacing look with the rear wheel bolts loose? Does the frame 'pull in' much when you tighten the bolts up? Is it because your hub is 110mm spacing to allow for snail cams but with the Onza you don't need them? Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 19, 2009 Author Report Share Posted December 19, 2009 That's a bit weird. I guess if you can get away with changing the BB length then that would help but 127.5/128mm is pretty much standard for ISIS these days anyway. How does the spacing look with the rear wheel bolts loose? Does the frame 'pull in' much when you tighten the bolts up? Is it because your hub is 110mm spacing to allow for snail cams but with the Onza you don't need them?no not really its a pretty nice fit on backend of dropouts Quote Link to comment Share on other sites More sharing options...
Muel Posted December 19, 2009 Report Share Posted December 19, 2009 (edited) Thought about asking Onza about it?They sometimes answer emails over the weekend. Edited December 19, 2009 by Muel Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 19, 2009 Author Report Share Posted December 19, 2009 Thought about asking Onza about it?think i will, unless joe@onza replies soon Quote Link to comment Share on other sites More sharing options...
Muel Posted December 19, 2009 Report Share Posted December 19, 2009 http://www.trials-forum.co.uk/forum/index....howtopic=145697Could also ask that guy for help?Where abouts is it rubbing, can you get pics? Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 19, 2009 Author Report Share Posted December 19, 2009 ok people cheers for your advice, i think ill give a narrow bb a go Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 19, 2009 Report Share Posted December 19, 2009 Dude I had this problem on my skull and it made me wanna smash it, really, however there is an easy solution.Turn the sprocket round so the teeth are next to the spokes rather than the drop outs.Problem solved for me anyway, I have an echo TR hub and it worked on that anyway Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 19, 2009 Report Share Posted December 19, 2009 Dude I had this problem on my skull and it made me wanna smash it, really, however there is an easy solution.Turn the sprocket round so the teeth are next to the spokes rather than the drop outs.Problem solved for me anyway, I have an echo TR hub and it worked on that anywayI've done that before with a threaded sprocket but had to make a thin shim because the chain was getting caught on the spokes without one. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 19, 2009 Report Share Posted December 19, 2009 Yes, this is why I pointed out that I have an echo TR hub it has a section of unthreaded shoulder by the flange which is enough to give clearance. Quote Link to comment Share on other sites More sharing options...
Jack_M Posted December 19, 2009 Report Share Posted December 19, 2009 (edited) Hey buddy. I had a little trouble building up my limey 320 for the same reasons. My spec ended up asMonty cranks with trialtech ti halfring and monty freewheelWipperman 808 chain (its 8 speed, so narrow)Monty rear hub with 4 mm of washers on the driveside end of the axel to space it out to 110mm.Monty 12 tooth rear sprocketMonty 124mm BBThe most important part of all this was the monty BB, and trialtech halfring for me.If you have issues at the moment, why not try getting a thin spacer to go between your cranks and freewheel if you arn't already running a bashring in there. Be careful that you have enough threads left on your crank though. If that fails, the next question is, how straight is your chainline at the moment? If its straight, then flip your rear cog around so the teeth sit nearest the spokes, and make a small spacer so the chain doesn't rub the spokes, as the guys above suggested.If your chainline isn't straight, then its time for a new BB.Your rear hub may also be contributing because its probably a hub designed to run with snail cams at 116mm spacing, and therefore without snail cams, the threads for the rear sprocket may be very close to the end of the axel. Thats why flipping the rear sprocket round may help.Jack Edited December 19, 2009 by Jack_M Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted December 19, 2009 Report Share Posted December 19, 2009 Clicky Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 19, 2009 Author Report Share Posted December 19, 2009 Clickydanny i run isisIf that fails, the next question is, how straight is your chainline at the moment? If its straight, then flip your rear cog around so the teeth sit nearest the spokes, and make a small spacer so the chain doesn't rub the spokes, as the guys above suggested.If your chainline isn't straight, then its time for a new BB.Your rear hub may also be contributing because its probably a hub designed to run with snail cams at 116mm spacing, and therefore without snail cams, the threads for the rear sprocket may be very close to the end of the axel. Thats why flipping the rear sprocket round may help.Jackmy chainline is not straight, i run a t-master back hub 127 onza isis bb(gonna change it to a 122) trialtech cranksthink in the morning ill try some washers on the rear hub axle because its just going to eat through my frame because the chainline is so bad Quote Link to comment Share on other sites More sharing options...
ScottTrials Posted December 19, 2009 Report Share Posted December 19, 2009 I had this on my limey20, i got a bashring put on and new chain. Also what hub do you have on it at the moment? Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 19, 2009 Author Report Share Posted December 19, 2009 I had this on my limey20, i got a bashring put on and new chain. Also what hub do you have on it at the moment?i have a t-master mate Quote Link to comment Share on other sites More sharing options...
*Koxx hydroxx 2 Jack * Posted December 21, 2009 Report Share Posted December 21, 2009 same problem on my ice ive just left it ... fed up with it lol Quote Link to comment Share on other sites More sharing options...
