Le @ Tnn Engineering Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) A NEW SPIN ON AN OLD IDEA.Integrated Clamps and boosterTNN Engineering has designed an integrated booster and clamping system that removes all the weak links (Flexy long bolts, spacers and the plastic washer)By optimising the booster position along the centre line of the slave cylinder, all braking forces are directly on the booster instead of wasting braking power on the flexing bolts, spacers and the frame.BoosterComputer designed using the latest software and Finite Element Stress Analysis (FEA)Designed to be a perfect compromise between stiffness and light weight at 43 grams.Internal booster ribs dramatically increases the stiffness - "Like bracing on a bridge"ClampsDesigned with function and performance in mind.Clamps don't use standard plastic washers for quick and easy setup.Noticeable increased stiffness and locking power.Slim line and minimalistic design keeps weight down and allows for 2mm longer adjustment slots.A necessity if your clamps are maxed out of adjustment.Can be used with or without TNN Engineering's booster.Competition rules are as follows.Guess the Complete Ultimate system weight and LGM pads (bottom photo) weight to 2 decimal places. E.G 107.58 gramsOne complete system and LGM pads to give away closest,earliest guess win.One guess per person and editing of guess allowed.The competition will end on Monday morning 19th of October.Here's a clue the total weights between 105 and 110 grams.Good luck!They'll be in store the same time the competition ends. Edited October 12, 2009 by Le @ Tnn Engineering Link to comment Share on other sites More sharing options...
King C Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 108.71g (inc. bolts.) England.How is the stem cap a clue? Dont you mean system?Edit: Forgot 2dp. Edited October 12, 2009 by King C Link to comment Share on other sites More sharing options...
Muel Posted October 12, 2009 Report Share Posted October 12, 2009 106.27g (inc. bolts.) England. Link to comment Share on other sites More sharing options...
forteh Posted October 12, 2009 Report Share Posted October 12, 2009 105.87g England Link to comment Share on other sites More sharing options...
txt2007 Posted October 12, 2009 Report Share Posted October 12, 2009 106.47 England Link to comment Share on other sites More sharing options...
JamieWilliams Posted October 12, 2009 Report Share Posted October 12, 2009 106.66g (inc. bolts) WalesJamie Link to comment Share on other sites More sharing options...
Josh Greenan!!!!!!!!!! Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 103.56g england Edited October 12, 2009 by Josh Greenan!!!!!!!!!! Link to comment Share on other sites More sharing options...
totaltrials Posted October 12, 2009 Report Share Posted October 12, 2009 160.66g englandHere's a clue the total weights between 105 and 110 grams.Fail . Link to comment Share on other sites More sharing options...
Mikee Posted October 12, 2009 Report Share Posted October 12, 2009 108.72g England Link to comment Share on other sites More sharing options...
ZHI-sam Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 107.13g (inc bolts) englandlooks good, even if i dont win 1 i might buy one Edited October 12, 2009 by ZHI-sam Link to comment Share on other sites More sharing options...
hdmackay Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 105.86g Scotland Edited October 12, 2009 by hdmackay Link to comment Share on other sites More sharing options...
stoozie Posted October 12, 2009 Report Share Posted October 12, 2009 108.28g England. Link to comment Share on other sites More sharing options...
jambo Posted October 12, 2009 Report Share Posted October 12, 2009 106.30 ScotlandJames Link to comment Share on other sites More sharing options...
Dan Clark Posted October 12, 2009 Report Share Posted October 12, 2009 106.23g England. Link to comment Share on other sites More sharing options...
LiamWood! Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 109.77 grams. England Edited October 20, 2009 by LiamWood! Link to comment Share on other sites More sharing options...
Jamie East Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 106.43g England Edited October 12, 2009 by Jamie East Link to comment Share on other sites More sharing options...
onzatrip Posted October 12, 2009 Report Share Posted October 12, 2009 107.48 (inc bolts) england Link to comment Share on other sites More sharing options...
Sam Moss Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 106.28g (england) Edited October 12, 2009 by Sam Moss Link to comment Share on other sites More sharing options...
Rusevelt Posted October 12, 2009 Report Share Posted October 12, 2009 Hmm, hard to gauge weather this set-up provides better stiffness than 4-Bolt boosters. Certainly an improved design over todays 2-Bolt booster. Link to comment Share on other sites More sharing options...
TROYston Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 105.98?? ENGLAND! Edited October 12, 2009 by TROYston Link to comment Share on other sites More sharing options...
Matt Vandart Posted October 12, 2009 Report Share Posted October 12, 2009 107.58 grams Wales Link to comment Share on other sites More sharing options...
eskimo Posted October 12, 2009 Report Share Posted October 12, 2009 106.77 grams Good luck Link to comment Share on other sites More sharing options...
Headley Posted October 12, 2009 Report Share Posted October 12, 2009 106.12 England Link to comment Share on other sites More sharing options...
SuperDeathMonkey Posted October 12, 2009 Report Share Posted October 12, 2009 109.48g England Link to comment Share on other sites More sharing options...
Jake Beach Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) 107.35g England Edited October 13, 2009 by Jake Beach Link to comment Share on other sites More sharing options...
