My Echo Lite 8.6 Kg.....beautiful Photos=)
Jeff
Complete:
frame: Echo lite long 1025 Jeff edition 1.7kg
fork: Echo urban 07 Jeff edition
bar: TryAll rage bar raised 690
Grips: Sticky and soft :shifty:
stem: Echo Jeff edition
Headset: no name 90g Jeff edition
Chain: shimano HG 51
Cranks: Tensile 165
Pedals: Wellgo MG-1
Bottom Brackets: Echo
Freewheels: Tensile
Bashrings: Tensile Jeff edition
Boosters: Czar Jeff edition
front brakes: Avid SD Ultimate
Brake Lever: Avid sd7
Brake Pads: Hand made
rear brake: Echo with Czar CNC Lever Blade Jeff edition
Brake Clamps: Gu
Brake Pads: Rock
Front wheel: 1kg
rim: Dob Jeff edition
Spokes: no name + V!Z Alloy Nipples
Hub: Chousen Jeff edition 90g
Tyre: Michelin Mambo
Tube: no name
Rear wheel:
rim: Echo 07 Jeff edition
Hub: Echo 13т
Tyre: Maxxis Creepy Crawler 19*2.5
Tube: no name
Coments welcome :rolleyes:
Edited by Jeff
Some very interesting ideas on weight saving, when I say interesting I mean good. Maybe not for the harsher/heavier rider but I can see something like that doing me rightly.
I'd maybe suggest getting a rat tail file and filing your chamfer's around the drilling bit's, mainly for aesthetics but in theory it would also remove any stress risers same would go for the rims too, but I'd imagine you've considered all this before taking the dremel/drill to it!
still, very nice indeed!!
Edited by Jakers
Heheh, nice.
Drill your brake clamps.
Drill your handlebar (just the grip area), not only saves weight, but I heard it could make the grip more secure)
Anyone dare to drill the steerer tube? (just the top part where the stem is being clamped on)
Yeh trim alternate blocks of tread off the tyres, I saved 130g in total and I'm certain it grips better in mud and on the edges of things.
Very nice, I have some interesting ideas. :shifty:
