Boswell Posted June 26, 2007 Report Share Posted June 26, 2007 Do you feel that a set of soft pads on a smooth rim can ever be as good as a set of hard pads on a ground rim? Please give me your views. Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted June 26, 2007 Report Share Posted June 26, 2007 (edited) yes! im running plaz on smooth, brakes immense and there made for a grind, i was orginally using one rock pad and one sink' snowy both on smooth with tar. alot of pads that are made for grinds are actualy good on smooth too..except koxx blues! smooth - saves rims - longer lasting pads - beast! zoo pads, with tar on smooth is immesnesink' snowys on smooth with tar is immense echo pinks ' ' is immesneive only had bad luck with grinds! Tim. Edited June 26, 2007 by Tim H Quote Link to comment Share on other sites More sharing options...
jsychem Posted June 26, 2007 Report Share Posted June 26, 2007 Hard pads setup well on a grind will always be better!Also, grinds works in the wet. Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted June 26, 2007 Report Share Posted June 26, 2007 Hard pads setup well on a grind will always be better!Also, grinds works in the wet.i say different, alot of pros are now using smooth.ive seen/riden/heard better brakes on smooth than i have with grinds. so i vote smooth!Tm. Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 26, 2007 Report Share Posted June 26, 2007 i say different, alot of pros are now using smooth.who?natural riders won't use smooth because the brakes might get wet, wet smooth rims = no brakesi can see some street riders using smooth, but not many. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted June 26, 2007 Report Share Posted June 26, 2007 yes! im running plaz on smooth, brakes immense and there made for a grind, i was orginally using one rock pad and one sink' snowy both on smooth with tar. alot of pads that are made for grinds are actualy good on smooth too..except koxx blues! smooth - saves rims - longer lasting pads - beast! zoo pads, with tar on smooth is immesnesink' snowys on smooth with tar is immense echo pinks ' ' is immesneive only had bad luck with grinds! Tim.Even magura blacks are good with tar, so you can't say those pads are good on a smooth rim. ANY pad will be with tar.Thats why people have grinds, tar and water don't mix well and you'll soon find your brake stops working entirely. Quote Link to comment Share on other sites More sharing options...
Up'n'away Posted June 27, 2007 Report Share Posted June 27, 2007 Thats why people have grinds, tar and water don't mix well and you'll soon find your brake stops working entirely.Yep, tar is the worst thing when wet, almost now braking at all..Recently did a medium grind, and run the Coust Cnc Pads and i must say, them with a grind were better than any Koxx on a grind.. Quote Link to comment Share on other sites More sharing options...
bowman12 Posted June 27, 2007 Report Share Posted June 27, 2007 Yep, tar is the worst thing when wet, almost now braking at all..Recently did a medium grind, and run the Coust Cnc Pads and i must say, them with a grind were better than any Koxx on a grind..I rode this guys bike last monday, those pads on a grind are immense. I've used Koxx browns with a bit of Monty brake on a smooth rim and that works well!! Quote Link to comment Share on other sites More sharing options...
