M-a-d Phase 1.3
Marky_J
They are fairly good bikes, are really good quality and finish.
With the 1.3 the forks only have a Disc mount, no canti studs for Vee brakes, and no 4 bolt mounts for magura's, so this can be a pain if the disc isn't good.
Personally, if you could stretch to it, I would get the 1.2, for £200 extra your getting a nicer colour, Twin Hydraulic Hs33 brakes, and better spec in other areas (I think wheel or cranks).
But as a starter a 1.3 would do fine.
ive got one had a topic a few weeks ago about upgrading it had it just shy of 2 months, for the price you cant really go wrong but ive found the back brake terrible, front is ok, rear hub is lame, my gears skip but im not sure if that is just bad set up frame seems quite good but now i want a mod because i had a go on a gu typhoon and it was soooo dam easy on the back wheel, if ur just starting out u might wanna consider mods aswell,
click this link to my topic
hope that helps, mike
