How To Build Your Own Freewheel Remover
Kevin Minato
Alright, so I could not find a freewheel removing tool at any of my local bike shops so i made my own.
and it actually worked.
How To build
Supplies
a) A solid strong piece of wood
b ) 4 long screws
c) 1 Hanger Bolt
d)Drill
e)Pen
f) ruler
How to build
a)make a perfect X on your wood with a pen
b ) measure the diameter of your freewheels slots
c) divide that number by 2
d) take that length and measure out from the center of the center of the X on all sides
e) drill holes at those points
f) screw your holes into the drilled sections
g) now drill the hanger bold into the center of the X
h) now test to see if your freewheel fits on your homemade freewheel remover
i) if your screw heads are too big to fit in your freewheel slots just file them down a tiny bit
Your final product should look like this
Now to use
bolt your freewheel on to Homemade Freewheel removing tool
and now turn your crank anti-clockwise
MAKE SURE YOU USE STRONG WOOD OR THIS WILL HAPEN
I was planning on making a similar thing out of steel, but I only deal with Tensiles now, that's all me and my brother have.
I was going to make an X shaped thing out of steel with a hole to bolt it in with, but I needed some 10mm+ steel and I never got round to getting any. (Dad's works has a few bits knocking around).
Tis a good idea though, well done. (Y)
